TPS Essential ?
BigMac
TPS Essential ?
Post by BigMac » Tue Feb 21, 2017 2:29 pm
Hello
I worked with a couple of ECU that required the Throttle position sensor be connected and working regardless of whether it was used for tuning
and another ECU that could be tuned on speed/density without need to connect the TPS although it was an option to use TPS signal for accel enrich etc
Question is whether the EMU will operate without TPS connected ??
Thanks :D
pric
Re: TPS Essential ?
Post by pric » Tue Feb 21, 2017 5:19 pm
You definitely need it for acc. enrichment and idle activation.
Mercedes C280 M104 Turbo
Re: TPS Essential ?
Post by RHD » Wed Feb 22, 2017 12:47 am
Yes as above... but the engine will still run
