2jz gte vvti no spark
i got everything wired up through the included pinout and help from zack.
it is a 2jzgte vvti. running 2jzgte NON vvti coils.
cam and crank signals are syncing. injectors are working, i have power to the coils from the relay verified by a multimeter, but i have no spark.
the oem igniter chip is not there, i have the emu set up to run coils without amplifiers, just cant seem to get any of the coils to fire.
Re: 2jz gte vvti no spark
Have you tried testing it via the "Test Output" function?
tested all outputs, tested all outputs in multiple coils to make sure i didnt swap some wires around. swapped pins, still nothing. tried different coils, nothing.
emu says its firing, coils say different.
hi,I have the same problem,I can not find what it is.you can help me
Have you used the "Power Transistor unit " or not ? It changes the "Dumb Coil" into the TTL logic....
I am using Bosch smart COP and it works fabulous.
I'm using original all-in-one is manifold intake
I dont speak your language. Was talking about coils, electronic components, not about intake manifold...........kelo62 wrote:I'm using original all-in-one is manifold intake
I know and sorry I'm just saying what's all oem sensor
- tommyboyblitz
Can you attach your setup files for your emu so we can have a look at your settings?
fataznwithcake
Silly question, but did you rewire the engine harness so that the ignition signals would go to the coils instead of the igniter?
