Idle drop finetune
Posted: Sun Apr 23, 2017 1:01 am
Hi, i would like to ask for your tricks or experience how to finetune idle control.
Main issue i have is idle drop under target after slight engine rev up. Most can be catched by activation DC additive, but activation triggering is limited logicaly minimum to over 1% tps. So there is a situation, where i can rev up engine even on 1% = still in idle control and after throttle closing is there a slight drop.
Issue is on cars with big throttle body and sligtly cammed engine.
I can be "fixed" by lowering maximum rpm for idle control, but it results in pulsing or rpm hangs afterstart when engine revs up itself over maximum rpm.
Its connected to RPM ref table and cranking DC. Maybe have these to able to corrected by CLT can help(correct ref table to resulting same values as normal DC ref , or crank duty lower to avoid large afterstart overshoot).
Did not try PID control yet, but assuming it will not help because triggering of the issue is the same.
Not using DC error table, it makes it worse. Also ignition control, but it can be slowered to make less harm and still used to smooth static idle.
How did you fighting with these?
