BMW e46 M54b30 DBW idle issues
Posted: Tue May 23, 2017 6:41 pm
by Bimmer
Anybody knows how to set up M54 dbw ? i have idle 1400 when it should be 900 i have problem with min position of throttle body, it is 4% but target is 1%, when i turn ignition off throttle body 0 position is not fully closed, and as i understand original ECU can change polarity of throttle body and turn it backwards ? am i right ? basic question is how to set up e46 m54 engine throttle body so it can idle normaly.
Re: BMW e46 M54b30 DBW idle issues
Posted: Wed May 24, 2017 9:07 am
by Nightsmoke
Are you using the original throttle?
Try changing the first colum in DBW characteristic to 1 or 0
Posted: Mon Jun 05, 2017 11:04 am
by Bimmer
Nightsmoke wrote:Are you using the original throttle?
There is no point changing that, because my actual value stays always in column with 5%. So red crosshair is always above the 0 column...
Posted: Fri Jun 16, 2017 9:56 am
I thought the actuator is normally spring loaded all the way to fully closed... but i may be mistaken?
Posted: Fri Jun 16, 2017 11:46 am
by Karel
Did you calibrated the Pedal Position Sensor ?
