Hello.
I've here a Celica GT4 and bought a PnP module for it. I just asked an module with an extra harness for use it with coils instead of the distribuitor, run an IAT sensor and to eliminate MAF.
In the beggining I couldn't control fuel pump relay because I didn't knew that I needed to configure switches inside the module. I've configured it and now I can control it. But I can't control main relay and I think that because of it I haven't any fuel being injected.
I have the car ready to be started and I'm having this problem now.
I've readed a very similar topic on this forum but there isn't any solution for this.
Best regards
Celica GT4 3SGTE ST185 won't start with PnP module
rockyboist
Re: Celica GT4 3SGTE ST185 won't start with PnP module
Where did you get your PnP from? You should upload your map and logs so people will be able to help you better. I can compare your base map to mine to check the differences in settings.
