2jz plug and play
Posted: Mon Feb 05, 2018 12:43 pm
by Jonny mac
hi, is there any plug and play ecu master patch harnesses available for a jzs161 aristo?
I'm fitting a jzs161 aristo engine and loom into my mkiv supra and I have just finished extending the loom into the cabin and have all oem body connectors wired into the loom also
I think I'm going to have a lot of problems with the idle control and dbw setup as my car only has a throttle cable
I can use the throttle cable on the jzs161 but the etci-s motor doesn't allow it to fully open the throttle
so I'm thinking about ditching it all and running an standard throttle body without dbw and an aftermarket 2 wire idle control valve off the ecu master
looking for something like this:
https://www.driftmotion.com/ECUMASTER-E ... dm3240.htm
Re: 2jz plug and play
Posted: Sat Feb 24, 2018 1:28 pm
by Zazzn
Nothing that i know of because you are looking for VVTI if it's the jzs161 engine. You'll need to contact autosport wiring harness to see if he can fab one for you. I talked to ECUmastersUSA and they said they can't get reliable stock on the VVTI connectors which is why they do not offer the solution.
