Strange blank spots in log - SOLVED
Posted: Thu Feb 11, 2016 12:01 am
wanted to ask something about some strange logging issue that is bothering me from the beginning. I have attached a log to the topic. If you switch to Trigger sync status and Trigger error you can see on a few occasions that the sync is reported as lost and on one place even that a secondary trigger error appears. Strangely the car drives perfectly and i am not even able to feel the trigger being lost. I suppose its possible the trigger to miss for a milisecond due to a noise or something, so i suppose i shouldn't worry about these ? However the main issue that i am wonderg about is that, if you switch to MAP value and VE you can see on several occasions that the map goes out of the bad like 10K or something and same for the VE. During this time the car drives perfect however the ECU sync shows red and reports non synchronised and the AFRs are frozen. This happens randomly and the only trouble is that its plaguing my log. Could it be that my Laptop is too slow ? I can see that during logging the CPU is between 85% and 90+%, however it does not seem to reach 100. Its an old laptop with Pentium M inside, so i am wondering if it may be the cause of these blank spots. Forgot to mention. The engine is 3SGTE gen2 JDM with stock turbocharger CT26. The car has no mods except the ECU
