Ford Duratec with Coilpack
Posted: Sun Mar 25, 2018 2:03 pm
by AdamQ
I'm just seeking confirmation really. I'm using the ECU on a 2.0 Ford Duratec engine with the coilpack mounted at the rear of the head. It's a wasted spark system. The coilpack has three inputs: ignition driver 1, +12V feed, and ignition driver 2.
Can anyone confirm the settings and entries for the Ignition outputs - in particular 'Coils type' and 'Ignition events' 1 and 2?
Many thanks,
Adam
Re: Ford Duratec with Coilpack
Posted: Sun Mar 25, 2018 5:23 pm
by Karel
The middle will be the 12V source, and pins 1 and 3 will be connected to ECU ignitior outputs 1 and 2. The firring order will be 1,2,1,2... you will runn in wasted spark mode..... so simple is it. And it is a Coil without amplifier
Posted: Mon Mar 26, 2018 7:31 am
by AdamQ
Hi Karel,
Perfect - thank you very much indeed.
Regards,
Adam
