Pops and bangs
Posted: Sun May 27, 2018 1:56 pm
by pepifebles
Hi guys, Iām trying tune for get pops and bangs but dont get anything
Retard ignition and enrich mixture in vacuum cells not work. Any advise??
Re: Pops and bangs
Posted: Tue May 29, 2018 7:34 pm
by maKe
You mean between shifts and when deaccelerating? I don't get bangs there because it cuts fuel immediately when lifting throttle. Rev limiter is ignition + fuel cut strategy and it's like AK47 gunshots when spinning 2nd and 3rd to 8200rpm's.
Re: Pops and bangs
Posted: Tue May 29, 2018 8:47 pm
by pepifebles
maKe wrote: āTue May 29, 2018 7:34 pm
Yes, between shifts and decel. How can get it?
Re: Pops and bangs
Posted: Tue May 29, 2018 9:07 pm
by pepifebles
Its possible that dont fuel cut inmediately?
Re: Pops and bangs
Posted: Wed May 30, 2018 10:33 pm
by pepifebles
Something like this will be happy
https://youtu.be/AvrY1dUm7r0
Re: Pops and bangs
Posted: Sun Jun 03, 2018 8:39 am
by maKe
Try to look into fueling -> fuel cut tab and see what happens when you change overrun fuel cut decay rate and resume enrichments. I really have no other clue other than just bump up fueling in the vacuum cells also. Maybe injection angle might have a desired effect if you try to inject "too late" in the low vacuum cells when lifting throttle.
Re: Pops and bangs
Posted: Fri Jun 29, 2018 8:18 pm
by rolfts
the folowing wil only make flames and minor bangs:
- go to your fuel cut tab
- make sure it wont cut fuel under deaccel
- bump up either condition under which it wont cut the fuel (fuel cut underpressure/tps limit/rpm limit)
- check the box with (dissable spark when overrun....)
- make make the low map cell's in your VEtable lower than lambda 1 (you need a lean mixture for it to self
combust) experiment with the exact lambda value you need for your pops.
you are now obligated to post a movie of your result here
Re: Pops and bangs
Posted: Sat Jul 21, 2018 11:52 pm
by pepifebles
Hi, sorry for delay. I try this setup. Thanks.
If I get it, upload video
Re: Pops and bangs
Posted: Wed Aug 01, 2018 2:32 pm
by Schlander
rolfts wrote: āFri Jun 29, 2018 8:18 pm
Lower than 1?? Then it would be rich?
Pops and bangs
Posted: Mon Sep 03, 2018 3:02 pm
by MichaelShock
For those of you out there running the Eurocompulsion Pops and Bangs update is it worth it? I am tempted to get it however I am concerned it might be a little too obnoxious for daily driving? Is there a way to have it only on in sport mode perhaps? How does it effect fuel economy? Let me know your thoughts Thanks
Re: Pops and bangs
Posted: Mon Sep 17, 2018 8:04 pm
by pepifebles
It depends on how aggressive you set it. I personally like it and it only works under certain conditions. Driving normal should not do it. You can activate it with switch
