Bluetooth module problem
chris72
Post by chris72 » Thu Oct 16, 2014 8:59 pm
Hi
i think my bluetooth module has failed, i can no longer connect any device or find EMUBT by scanning.
there is also no light from the device.
Is there anything else i can check or do i need to return BT module ?
Re: Bluetooth module problem
Post by Jadzwin » Fri Oct 17, 2014 10:21 pm
Was it working before ?
chris72
Post by chris72 » Sat Oct 18, 2014 9:18 pm
Hi
yes module was working without problems, i think it stopped after a firmware update to 1.60
Post by Jadzwin » Mon Oct 20, 2014 2:55 pm
but the LED does not depend on any software. It is jus hardware that shows the state of BT communication chip.
So if the LED does not light, it means thate there is no power on BT module or BT module is broken.
chris72
Post by chris72 » Mon Oct 20, 2014 5:52 pm
Is it ok to open the plug to check for poor connection without voiding warranty ? if ok i will check this first
