as above.
when i put in say 6 tooth..trigger on 2e..
make permanent..
as soon as i trun off the ignition the settings go back to 2 tooth and trigger on 0.
what could be wrong?
1e trigger settings keep on changing on fresh ignition.
ESRA Car performance
Re: 1e trigger settings keep on changing on fresh ignition.
As I know you are set up subaru 6 tooth trigger.
This trigger is for 4 cylinder subaru engines, and some parameters like num cylinders and num tooth are fixed and you cannot change it.
