Page 1 of 3
ANDROID DASH - VERSION 2.1.0 - Available in Google Play
Posted: Wed Aug 13, 2014 11:10 am
by Kisielisodd
ECUMASTER ANDROID DASH already available in Google Play!
https://play.google.com/store/apps/deta ... ev.emudash
ECUMASTER DASHBOARD connects to ECUMASTER EMU engine management system via BT module, showing real time data of critical engine parameters. All data also could be stored to log file for further analysis.
Please check http://www.ecumaster.com for more information.
The followings parameters could be displayed:
- RPM
- MAP
- TPS
- IAT
- AFR
- CLT
- LAMBDA
- BATTERY VOLTAGE
- IGNITION ANGLE
- INJECTORS PW
- SEC. INJECTORS PW
- INJECTORS DC
- EGT #1 and #2
- KNOCK LEVEL
- DWELL TIME
- CURRENT GEAR
- BARO PRESSURE
- ANALOG #1,#2,#3,#4
- ECU TEMPERATURE
- OIL PRESSURE
- OIL TEMPERATURE
- FUEL PRESSURE
- ETHANOL CONTENT
- FUEL TEMPERATURE
- VEHICLE SPEED
- FUEL PRESSURE DELTA
- FUEL LEVEL
- TABLES SET
- CHECK ENGINE CODE
Re: ANDROID DASH - VERSION 2.1.0 - Available in Google Play
Posted: Mon Jun 29, 2015 12:24 pm
by BigMac
Looks good and I'd like to make use of this but I'm a bit of a retard when it comes to phones and tablets etc
I have a Motorola with Android software and I see 10" tablets on Ebay for about £50 with Android Is it the same software for both phone and tablet ?
Can data logging be done to the phone or tablet ?
Posted: Mon Jun 29, 2015 5:55 pm
by nyl
I wan't to use wide display with arduino board. Can it be modified for that display, it's my personal project :D
Posted: Mon Jun 29, 2015 11:45 pm
by astra vxr
BigMac wrote:Looks good and I'd like to make use of this but I'm a bit of a retard when it comes to phones and tablets etc
yes android is android tablet or phone its the same :) i no there was a problem with the bluetooth on some tablets i dont no if thats been fixed yet
Posted: Tue Jun 30, 2015 12:16 am
by BigMac
Was looking at this on Ebay with Bluetooth 4.0
http://www.ebay.co.uk/itm/10-INCH-QUAD- ... 2a4a52f9fc
Posted: Tue Jun 30, 2015 2:44 pm
by Alec
I'm still having issues with MAP display in imperjal units along with fuel pressure delta not working.
Posted: Tue Jun 30, 2015 6:22 pm
by pepifebles
My android phone connect perfectly but dont read any parameters. All show 0.
Posted: Tue Jun 30, 2015 6:48 pm
by Karel
pepifebles wrote:My android phone connect perfectly but dont read any parameters. All show 0.
and did you configured your emu output ?
Posted: Wed Jul 01, 2015 12:05 am
by pepifebles
Ups :o each day learn new things
Can I connect android app by usb (faster than BT)?
Posted: Wed Jul 01, 2015 7:45 pm
by Flemme
Looks cool!!!
Posted: Wed Jul 01, 2015 9:34 pm
pepifebles wrote:Ups :o each day learn new things
Only BT connection is possible
Alec wrote:I'm still having issues with MAP display in imperjal units along with fuel pressure delta not working.
It is on our to do list and will be fixed/ added in next software update
Posted: Sat Jul 04, 2015 2:29 am
by BigMac
Got it working eventually :D
Posted: Mon Jul 27, 2015 3:32 pm
by ezukas
I'm not sure where it is better to post feature request for Android app - here or under common topic "Bugs and Feature requests". In order not to mix into common pool with firmware and PC app I'm posting here.
Two very much needed features for the Android Dash:
* Auto Connect [Enable/Disable] - when Enabled automatically connect to predefined paired device and automatically reconnect after loss of connection;
* Auto Start Logging [Enable/Disable] - when Enabled automatically start recording log file after establishing connection.
Many thanks
Posted: Mon Jul 27, 2015 5:49 pm
by roquete
ezukas wrote:I'm not sure where it is better to post feature request for Android app - here or under common topic "Bugs and Feature requests". In order not to mix into common pool with firmware and PC app I'm posting here.
Many thanks
+1 on that
Posted: Mon Aug 17, 2015 9:26 pm
by derOJ
I habe problems with logging.
I made 4 Loge with the app but Windows client cannot read them.
Two of the logs Werke at least 2 Minuten long.
But client only shows 10 seconds or so....
by derOJ
And the fourth...
Posted: Wed Aug 19, 2015 9:36 pm
by derOJ
I tried two more logs....but client does not open them...no errors, or messages...just no graph...
Stupid question: Do I have to be connected to emu???
Posted: Sat Aug 22, 2015 11:10 pm
by roquete
Yes you do, first pair your phone/tablet with bt to "emubt" device, use code 1234.
Then open the app and choose "emubt", dont forget to choose ecumaster serial protocol in EMU.
Posted: Sat Aug 22, 2015 11:13 pm
by roquete
Feature request:
Option to choose the logs folder location, and/or upload or share to a dropbox or cloud account.
Great app keep up the good work, tanks.
