In the new firmware/software for Race Technologies Dash2 you have to select which ECU you are receiving data from and ECUmaster is not listed in there.
I currently have it setup using the old firmware on the Dash2 and output on the EMU set to 'Race Technology Dashboard' which works fine but I would like to update the Dash2 which means having to change to the new software which does not have the ECUmaster listed.
Can you advise on how I set this up?
Thanks,
Edward.
Race Technologies Dash2 and EMU
Re: Race Technologies Dash2 and EMU
I just found this reply to a similar question from Race Technologies themselves, it may help someone in the future that is looking to setup their Dash2 with the new software.
"Hi There,
The ECU master EMU is able to output the Race Technology RS232 data protocol, therefore there is no need to select the ECU from the ECU interface drop down list. Please set this to "Disabled".
Please ensure that you have made the connections required by the ECU as per the below link and also that the Race Technology data protocol has been selected in the ECU mapping software.
http://www.race-technology.com/wiki/ind ... EREMUV1-23
The full list of channels available from this ECU is also available in the above link for your reference.
Kind Regards,
RT Support (SK)"
"Hi There,
Kind Regards,
RT Support (SK)"
