Hi ,
Can somebody post their fuel log file here from a normal good driving car ( mine is 4 cyl , 2000cc , turbo ) to compare with mine ?
I know every engine is different but i would like to compare as my engine is very hard on low revs.
With standard ecu the engine is much,much smoother and i don't know very well if i am to rich or to lean ?
Once over 2000 rpm and more throttle everything is ok.
It is a normal turbo engine , so no race cams or anything.
Thx
Log file
Re: Log file
Don´t you have a wideband connected? Tune the car without EGO correction aiming at 14,0 in afr or 0,95 in lambda on the N/A side of the map before activating EGO. Please post your map.
