No Spark on SR20DET, wasted spark
Posted: Tue Nov 18, 2014 6:57 pm
by clem
Hello there!
I have wired an EMU to my sr20 powered S13. I am using a bosch 2x2 double fire coil without amplifier, and there is no spark appearing...
Ignition status is synchronized, but with the timing light says that there is no spark. The car never run before and I am wondering if there is a hidden spark disable function similar as for injectors? Any Idea for that problem, or has anyone had a similar problem before? Coil fuse is ok, all other fuses too.
Many thanks
Greetings from austria
Clemens
Re: No Spark on SR20DET, wasted spark
Posted: Tue Nov 18, 2014 7:31 pm
by PSI-Motor
Din you activate the ignition outputs under ignition outputs?
Posted: Tue Nov 18, 2014 7:40 pm
by PSI-Motor
Posted: Tue Nov 18, 2014 10:47 pm
by clem
Hi, thanks for your reply.
yes I had activated the outputs, like in your description. see my picture:
is there an other option to disable the coils to fire?
Posted: Tue Nov 18, 2014 11:10 pm
Please send a picture of you ignition configuration and log file from cranking.
Do you use Nissan trigger ignition type ??
Posted: Tue Nov 18, 2014 11:32 pm
by clem
Well I connected the Coil like in the EMU manual described. Battery to coils via 15A fuse, each coil to one Ignition output (output 1 (G8) for cyl 1&4 and output 2 (G16) for cyl 2&3). I can not provide a log file until thursday night, sorry. which parameters would you like to have logged (or are all parameters included in the exported log)?
Yes I use the standard Nissan Cam angle sensor from this engine. Emu even says ignition is synchronized!
here my trigger settings:
Even if the engine won´t start because I connected the wrong ignition cables to the plugs, there would be at least a spark visible with the timing light...
thanks!!
Posted: Tue Nov 18, 2014 11:46 pm
by PSI-Motor
The 12v cable to the coilpack is ignitionswitched and not direkt from battery i hope?
Posted: Wed Nov 19, 2014 12:22 am
You have put VR sensor for CAM sensor type.
Here is proven trigger config for SR20DET
Check if there is +12V on the coils during cranking.
Posted: Wed Nov 19, 2014 8:47 am
by clem
Thanks for your help. I will check these settings when i can get to my car again! Sorry for the bad description, yes the coil is ignition-switched...
see you!
Posted: Sat Nov 22, 2014 12:10 pm
by clem
Hi there.
Thanks for your help! Car is running now (more or less), it is a question of tuning now.
The problems were: Firmware mismatch, Trigger settings.
Thanks jakub!!! Kind regards
clem
