hi guys just need to double check something
coming from megasquirt there isnt a lot of differences with the set up so i just wanted to check something
crank signal is 114 deg so my working out is tooth 9 is this correct ?
and trigger angle is 60 ?
on megasquirt we have trigger a and b and the return numbers ( on ms1 )
still waitng on my ecu ( long story ) but im just going through the settings and making sure ive got most of them for when it /if it turns up
thanks
tooth wheel
Re: tooth wheel
Yep, your guess is correct. Sound like Opel engine
Re: tooth wheel
correct !!
coming from megasquirt for the last 10 years it not a lot different then
thanks again
thanks again
