Hi
Some questions about the EGO correction.
1 The injector PW on the log , is this after the EGO correction or is this value before the correction has taken place.
2 I see on the EGO correction% log graph almost alway's below 100% Never or rare above 100 %. I can see on the afr graph it should go also +100% many times Feedback + and - values are the same. ( +- 15 % )
Grts
Patrick
EGO correction
Re: EGO correction
And it not because all VE is to rich.
When i drive whitout EGO the AFR is not to bad, lean and rich from time to time.
Can i check how much the EGO is changing the injector PW.
Re: EGO correction
Hi!
The pw is the final injectors opening time. The ego correction in % is EGO Correction.
Maybe your EGO feedback settings are too sensitive ?
