CBR 600rr coils
Angelo S38
CBR 600rr coils
Post by Angelo S38 » Mon Feb 02, 2015 11:30 pm
I'm planning on using, denso stick coils on my S38B36 bmw engine they're of an CBR 600rr.
Part Number 129700-4510
Has anybody used these coils with the EMU before? Can I run 6 of these straight of the EMU or should I use an ignition module?
Any recommendations on the dwell settings?
Thanks,
Angelo
Re: CBR 600rr coils
Post by Jadzwin » Mon Feb 02, 2015 11:35 pm
You can connect them directly to EMU...
Angelo S38
Re: CBR 600rr coils
Post by Angelo S38 » Mon Feb 02, 2015 11:41 pm
Hi Jadzwin,
Thanks for the swift reply, so power consumption wouldn't be too high?
Any idea on the settings?
PBU
Re: CBR 600rr coils
Post by PBU » Tue Feb 03, 2015 10:04 am
I would start at 2.5 msec PW and measure the current.
Keep it under 5 amp peak to be safe to start.
If you don't have the specs of the coil check the temp of the coil regulary .
PBU
Angelo S38
Re: CBR 600rr coils
Post by Angelo S38 » Tue Feb 03, 2015 11:23 am
Hi PBU,
How would you do that?
Would you use a microcontroller (to generate the PW signal) and measuring equipment similar to your injector testing setup?
Excellent job on that by the way.
I do have acces to a pulse generator so I might use that.
Angelo
astra vxr
Re: CBR 600rr coils
Post by astra vxr » Tue Feb 03, 2015 1:28 pm
Primary resistance 1.4 ohms
Volts Milliseconds
8 - 6.00
10 - 3.75
12 - 2.80
14 - 1.95
16- 1.60
Angelo S38
Re: CBR 600rr coils
Post by Angelo S38 » Tue Feb 03, 2015 2:03 pm
Yep found those values as well, I'm looking for some confirmation perferably with expercience on the EMU.
astra vxr
Re: CBR 600rr coils
Post by astra vxr » Tue Feb 03, 2015 2:30 pm
i would go with them numbers they look about right and just keep an eye on them (check for over heating )
i doesnt matter what ecu you have them on they all handle dwell about the same
Maciekx
Re: CBR 600rr coils
Post by Maciekx » Tue Feb 03, 2015 4:56 pm
From 12-16v @ 2.5ms setting cbr 600rr is running without any problems, so this information is safe for coils :)
PBU
Re: CBR 600rr coils
Post by PBU » Tue Feb 03, 2015 7:33 pm
Angelo S38 wrote:Hi PBU,
Angelo
No , just meaure when on the car. You need a current sensor and oscilloskop.
Grts
PBU
Angelo S38
Re: CBR 600rr coils
Post by Angelo S38 » Wed Feb 04, 2015 12:05 am
Thanks for the tips guys I'll start with these settings. (won't be for a while though)
But I still don't get how I should limit the current, as you say to 5A max?
Or Is this solely controlled by the dwell time and should I monitor it with a current sensor?
Thanks for the help!
Angelo
Angelo S38
Re: CBR 600rr coils
Post by Angelo S38 » Mon Feb 09, 2015 1:08 pm
For future reference
Did some more research on the subject and found the following article very helpfull. I think I get it now. :)
http://www.dtec.net.au/Ignition%20Coil% ... ration.htm
It describes a method for generating data on the bench as well. I think I'll try that first since it will be a while until I install it on my car. And I would like to do as much as I can to generate usefull data to speed up the actual on vehicle proces to keep downtime to a minimum.
Angelo S38
Re: CBR 600rr coils
Post by Angelo S38 » Wed Feb 18, 2015 10:35 pm
Did some measurements of my own, my power supply wasn't stable at 17v so I quit at 16v, here are the times I came up with for for 5A:
DENSO 129700-4510 J0451 dwell.xlsx
(10.93KiB)Downloaded 158 times
At 6 and 7 volts you don't reach 5A I do have the graphs as well in case anyone interested.
Re: CBR 600rr coils
Post by Jadzwin » Wed Feb 18, 2015 11:24 pm
Nice job!
