Hi there,
It's neccesary put swith to connect launch control or it's valid only activate it on emu software?
To activate als what its neccesary buy? Any valve?
Regards
Launch Control and ALS
pepifebles
The fun starts now
Re: Launch Control and ALS
For Launch cotntrol you can use option always active, and set activation when VSS < 1kmh and TPS > 70%
For ALS you need to provide additional air so I suggest to use throttle kicker. Be aware that during ALS work there is no vacuum and your breaks will not work as usual (servo).
pepifebles
Ok. Without ALS also will be funny.
Launch then can Connect switch button to analog input or always active. Thanks
Regards
Regards
The fun starts now
