No spark on 3sgte gen 2
Posted: Fri Mar 13, 2015 4:20 am
by Macmall10
Got my ecu master hooked up, but it just cranks and never gets spark? Plug in the stock ecu and starts up for a second, all wires check out correctly, not sure what else I'm missing, so im seeking help on here.
Re: No spark on 3sgte gen 2
Posted: Fri Mar 13, 2015 10:22 am
by Kisielisodd
Need more info about it. Did You use stock wiring ? or custom one, Are You using distributor, ignitor and stock coil or there is something custom ?
Posted: Fri Mar 13, 2015 4:20 pm
by ATS_Scott
This is one of the units I tested for CRW correct? If so, it started and ran an MR2 at my shop, one that had very weak crank/cam signals. I did not test with your EMU however, just the interconnector, and pigtail. I would confirm the EMU has the base map I sent installed before you do anything else. If you need it resent, email me scott@atsracing.net
It should be on all stock wiring and coil/igniter.
Posted: Fri Mar 13, 2015 4:35 pm
by Macmall10
Yea all stock wiring, coil, distributor checks out good, they got the other car in here at crw to start with the emu, so I went ahead and replaced my engine harness made sure everything was good, cranks good, no spark. I'm going to see if they can reload that basemap to give it a try.
Posted: Fri Mar 13, 2015 5:32 pm
by ATS_Scott
Macmall10 wrote:Yea all stock wiring, coil, distributor checks out good, they got the other car in here at CRW to start with the emu, so I went ahead and replaced my engine harness made sure everything was good, cranks good, no spark. I'm going to see if they can reload that basemap to give it a try.
I just sent you a basemap via email. Josh at CRW has my phone number if you need anything urgently.
Posted: Fri Mar 13, 2015 10:26 pm
by Kisielisodd
Send project and log from cranking to tech@ecumaster.com
Posted: Sun Mar 15, 2015 7:32 am
by Macmall10
Problem solved, put in a new distributor and car fired up right away!. Everything is good now! :D
Posted: Wed Mar 18, 2015 3:47 am
by Macmall10
How does the check engine light work on these things? What if it flashes for one second and never comes back how do I check that?
Posted: Wed Mar 18, 2015 11:36 am
by Kisielisodd
You can check it in log. Channel called check engine code
Posted: Wed Mar 18, 2015 7:39 pm
by Macmall10
I'm on the software 1.12 and I plug the ecu in and go to logs nothing showing check engine is there?
Posted: Wed Mar 18, 2015 9:48 pm
Probably it is WBO "error". It would be the best if you send here the log with this situation
Posted: Wed Mar 18, 2015 10:06 pm
by Macmall10
How can I send you the logs does it get saved in the emu folder in documents?
Posted: Wed Mar 18, 2015 10:23 pm
Just press the disc icon on the grpah log window. All log channels will be saved.
Posted: Wed Mar 18, 2015 11:45 pm
by Macmall10
Sometimes the ecu shuts off for a second and I have to turn off and on my car, Its when I have my laptop connected with 1.112, don't know if that's supposed to happen? It's only happened once today though. Where the car bogs down to a stop. But turns on great and drives again. I'll send you the data log I just made.
Posted: Thu Mar 19, 2015 12:28 pm
by Kisielisodd
Engine code that you see is knock. Your Engine obviously is not knocking. You need to configure knock sensor or turn off notification about knocking in check engine options.
Posted: Thu Mar 26, 2015 11:57 am
by Macmall10
So now I have a new problem, everytime I load my map to the ecu, it starts great then when I shit the car off, the check engine light doesn't come on, and have to reload the base map everytime I start the car up?? I've spent so much time and money trying to get my car tuned, even with some of the best tuners around, none can get this ecu to function correctly, and that's on 2 mr2's with the same setup. I have no idea what's going on, maybe I might need a whole new jumper harness, and ecu totey it out again to figure out my problem.
Posted: Thu Mar 26, 2015 12:47 pm
by Jan32
Did you make the settings/maps permanent with button F2 after loading it to EMU?
Posted: Thu Mar 26, 2015 2:53 pm
by Macmall10
Yea made sure everything was permanent, but somehow my cel doesn't come back on when I restart the car, I tried another emu ecu same map and same thing. I need to upload basemap on every startup now. Not sure what's going on, and I'm on the latest software
Posted: Thu Mar 26, 2015 4:57 pm
Let us connect to your ECU and check what is wrong.
Cantact as at tech(@)ecumaster.com
Posted: Thu Mar 26, 2015 11:01 pm
by Macmall10
Ok I've contacted you guys, I have teamviewer installed if you guys are ready to log into the ecu?
