sudden voltage drop problem
hi
I've been having sudden voltage drops in my own car.
when the ignition is on, there's no problem.
when the car is running, problem starts :
https://www.youtube.com/watch?v=430whKcu4aw
I changed the coils, crank sensor, ecu.
no solution.
I made new cables for coils, ecu power, and ecu ground, power ground,
no solution.
I disabled everything but the crank sensor, coils and injectors,
no solution.
I changed the fuel pump, also fed the fuel pump from another battery, no solution.
what is the problem, do you think ?
no solution.
no solution.
no solution.
Emu Distributor / Tuner
Re: sudden voltage drop problem
Did you test it without alternator? Maybe there is the problem.
I tried it already - no difference..
Jean Niemi
- Contact:
I used to see similar happening, but it was only with older SW/FW.
What Software/Firmware are you using?
Did you measure the same with an Multimeter or better an oszilloscope?
I dont have an oscilloscope, but I measured it with some multimeters, the multimeters dont show any voltage drop, however, they are not as sensitive as an oscilloscope.
Maybe try to mount a capacitor on the line of the coils, tell me if there are news.
Bye
Bye
could be battery ,alternator , or just a crap ground its not dropping enough to cause much problems so it will be something simple
I think I've found the problem.
I have another car (sierra dohc turbo) with the same setup, with the same problem.
both are wasted spark operated.
the other cars with sequential firing don't have the same stuff.
soo...
can it be because of wasted spark ?
soo...
It is rather connected to bad grounding. The coils draw lots of current and if they share ground with EMU it can make such problems.
Is the battery realocated from the hood ?
they dont share the grounding with emu. but I will check all the grounds again and report
are you useing brand new loom or useing adapter ?
two different fresh looms on two different cars.
Try to draw the schematic with ALL of your car grounds.
ok I will..
the voltage drops are more likely like parasites - not drops like heavy load as a fan turns on.
