RPM on ON Position :(
Posted: Sun Apr 12, 2015 12:34 am
by fonz87
Was wondering if anyone has had this issue. I m reading RPM when my key is ON position. This happen to me about a year ago and I grounded one one of the wire and the RPMs were gone but now its happening again and I havent touched anything. However, I m curious if one of the wiring are switched with the Crank Sensor, Would It cause the RPM to show up without the Car is turned on?
The RPM's are around 103-104
Re: RPM on ON Position :(
Posted: Sun Apr 12, 2015 2:35 am
The noise in the installation makes this issue. Just put pulldown resistor (2-10K) between sensor ground and primary trigger to suppress the noise.
Posted: Sun Apr 12, 2015 3:28 am
by fonz87
Is this the values or something I would input in the computer ?
Posted: Sun Apr 12, 2015 1:26 pm
Any resistor in this range should work.
Posted: Sun Apr 12, 2015 5:09 pm
by fonz87
Jadzwin wrote:Any resistor in this range should work.
Hey Jadzwin, I already have a Resistor on the car, I have a 2JZGTE swap with a resistor.
Posted: Sun Apr 12, 2015 8:56 pm
Are you sure you have pulldown resistor on primary trigger ?
It is not used in standard 1/2JZ application
Posted: Mon Apr 13, 2015 1:54 am
by fonz87
Hey Jadzwin
Disregard my post, I clearly can't read. The whole time, I was reading my log incorrectly and I thought I had RPMs showing on ON position but wasn't. It was my MAP sensor reading….. I m so dumb but anyways here is a video of my car running, Enjoy!
https://www.youtube.com/watch?v=lnxkwAi7xBE
Posted: Fri May 01, 2015 2:09 pm
haha.. even though your problem didnt actually exist sometimes it can exist!!
I had a car once that when you turn on the thermo fan with the engine stopped the rpm would start and even injectors sometimes tick because the crank sensor was mounted on the front of the engine close to the fan motor and was picking up magnetic signals from it! Interesting thing was it didnt actually affect the engine when it was running at all so i never bothered to fix it.
Posted: Sat May 02, 2015 11:20 pm
by fonz87
RHD wrote:haha.. even though your problem didnt actually exist sometimes it can exist!!
yea, well i was reading RPM last year on ON position but Zach helped me out and said it's the harness issue, I think I connect power ground to Ground to the ECU and it stopped the Noise and no more RPMs reading…
