HI
i would like to be able to change the boost target to suit track conditions without having to use the laptop everytime.
What i am planning to do is use a selector switch with several resistors to the gearbox sensor input
from this can i use the boost gears scale % target to offset the VSS scale that i need to use
Hopefully this should give me 6 levels of boost based on my VSS boost stratergy. So position 1 = 100 % of VSS table position 2 = 95 % of VSS table and so on
Is this the best way or am i over complicating things ?
Chris
Boost level adjustment input
Re: Boost level adjustment input
tagging along with this one chris sounds interesting wouldnt mind something like this for mine
It is good idea
Hi Jakub
so will this work ?
i am currently using open loop mode, i was not sure if the gear offset applied to the vss table or directly to the DC table
so will this work ?
