Full Sequential Injection VW 16V
Posted: Tue May 12, 2015 11:57 am
by Racekid21
Hi Guys,
I'm planning the wiring for my 16V Turbo Engine.
Is it possible to fire with Wasted Spark, but inject in full sequence?
What else could I do? I would like to trim each Injector- if the Exhaust Temp's would have big differences.
I have a Cam and a Crank-Sensor.
Maybe answers in German? :D
Thank you and have a nice week.
Re: Full Sequential Injection VW 16V
Posted: Tue May 12, 2015 12:02 pm
It is not a problem. Just pair the coils (1 with 4, 2 with 3) and use crank and cam sensor.
Posted: Tue May 12, 2015 12:13 pm
by Racekid21
Okay, that's what i wanted to hear :).
So Injector Phase would be 1342
And Ign. also, but 1+4 and 2+3 cables paired.
Am I right?
Posted: Tue May 12, 2015 3:24 pm
by Horsty
yes.
but why don't you use four coils for the ignition then and go for full sequential, too?
Posted: Wed May 13, 2015 1:59 am
by Racekid21
Because many people say, that there are no good coils for full sequence.
I want to go for a boost of 45 PSI- and around 8500rpm.
Posted: Wed May 13, 2015 1:43 pm
Check the following coils P65. It can give you over 70mJ of spark energy.
Posted: Sun May 17, 2015 11:33 pm
by alper
are these more powerful than the audi red coils ?
Jadzwin wrote:Check the following coils P65. It can give you over 70mJ of spark energy.
Posted: Mon May 18, 2015 8:27 pm
by Racekid21
Yes they are! And they are much cheaper than the Audi's.
They cost around 35 Euro.
Posted: Tue May 19, 2015 1:34 pm
by Horsty
you mean the ford transit coil?
Posted: Wed May 20, 2015 3:16 pm
P65 is bosch high performance passive coil.
http://www.bosch-motorsport.de/media/ca ... 131pdf.pdf
Posted: Thu May 21, 2015 8:19 am
by Karel
Jadzwin wrote:P65 is bosch high performance passive coil.
I am reading it and just wonder....
Why does it have 3 pins ? Why it has Ground, +12V and still no transistor ?
Is the Ground just for "shielding" ? And the rest is normal pasive coil so 12V input and EMU switches like dumb coil the other end ?
