Set-up for SR20DET CAS with 12-1 Trigger Wheel
Posted: Sun May 31, 2015 6:57 pm
I'm looking to set up my Alfa Nord motor to run sequential ignition and injection and plan on using the CAS from a Nissan SR20DET. I understand that these stock have been giving some errors in other people's builds due to the extremely fine slit size in the original trigger wheel,
To combat this, I plan on using a 12-1 trigger disc from diyautotune. These have a single Cam sync window on the outer ring, with 2 sets of 12-1 slots on the inner ring.
Is anyone successfully using such a set-up and if so, could you share your primary and secondary ignition trigger set-up tables?
The SR20DET CAS: And the diyautotune trigger wheel: Thanks & Regards,
Nick
Nick
