boost correction timer operation
Posted: Sun Jun 21, 2015 12:08 am
probably a question for Jakub
quick question about the boost correction timer
at the moment i have timer set for correcting boost from 25% to 100 % over 5 seconds. the question is what happens before and after the timer function ?
The bike is only used for drag racing and i need approx 25% of full boost at launch (100% throttle) ramping up to between 250 and 350 Kpa depending on track conditions.
i use VSS boost scaling of 25% at zero speed to set correct pressure during launch control after this VSS table is set to 100% of target boost i assume the timer function will overide this value while it is operating then at the end of timer return to VSS correction.
is this correct before i try it out on the bike
