nitrous input activation
Posted: Thu Jul 02, 2015 2:29 pm
by BigMac
Can the nitrous be activated by 12volt or grounding on the analog input ?
Re: nitrous input activation
Posted: Thu Jul 02, 2015 2:46 pm
analog inputs need signal from 0-5V so you will need a pull up resistor.
maybe best way to have the resistor (1K?) between the I/P and 12v then have your button pull the I/P to earth for activation, the rest is setup in the I/P configuration under sensor setup
Posted: Thu Jul 02, 2015 4:57 pm
by BigMac
Perhaps there is a way to utilise an LED which I like to use as an activation warning light maybe it provides a suitable volt drop some how?
I'm not into electronics that much to know
Posted: Sat Jul 04, 2015 1:38 pm
by BigMac
I've further studied the EMU system and will have to use a different method of wiring as I need an "instant on" push button for testing and priming the nitrous
which bypasses the conditions so the dedicated Nitrous parameters would only be used for enrichment and retard and the conditions on another output
