HELP Logging data with a AiM Solo DL
nico.n
Post by nico.n » Mon Sep 08, 2014 10:00 am
Has anyone managed to connect an EMU to an AiM Solo DL Data Logger?
Here's what I have done so far:
1. Connected the EMU to the Solo via the RS232 RX and TX cables which are pin 1 and 2 on the EXT Port
2. Set the Ext Port to "AiM Dashboard" in the software
3. Configured the Solo DL under "Device Configuration" I have set "ECU Manufacturer" = "AIM" and "ECU MODEL" = "PROT_UART"
This doesn't work. The Solo DL doesn't pick up any data.
I have tested the Solo with my Haltech Sprint 500 and it works perfectly via Haltech CANv2.
Has anyone managed to get this working???
Thanks in advance.
Nico
Re: HELP Logging data with a AiM Solo DL
Post by Jadzwin » Mon Sep 08, 2014 1:18 pm
Hi!
We have tested AIM Pista Dashboard over serial communication and works great.
We didn't tested over CAN however we will do in 1-2 weeks.
Did you try to swap TX and RX ?
What firmware version do you use ?
