acc enrichment lean spikes
Posted: Mon Aug 24, 2015 12:00 am
by dnusaath
cant get rid of these of these lean spikes when given sudden throttle. how do you properly adjust this? what should I be looking for when calibrating? when checking logs my acc enrich pw. never seems to move. I get slow engine reaction when given quick throttle acc. any help or advice on this. thank you in advance
Re: acc enrichment lean spikes
Posted: Mon Aug 24, 2015 12:34 am
by skogs
hi. You might find this thread useful:
viewtopic.php?f=19&t=90
Posted: Thu Aug 27, 2015 5:06 pm
by ATS_Scott
dnusaath wrote:cant get rid of these of these lean spikes when given sudden throttle. how do you properly adjust this? what should I be looking for when calibrating? when checking logs my acc enrich pw. never seems to move. I get slow engine reaction when given quick throttle acc. any help or advice on this. thank you in advance
The thread posted is going to very helpful, but also check your MAP sensor filter. There are some newer strategies depending on your Firmware Version that allow you to filter the MAP at higher RPM, but not at low RPM where it can cause poor throttle response. look under sensor setup, and MAP sensor.
Posted: Thu Aug 27, 2015 6:13 pm
If you use MAP filter try the new software (1.139)
In 1.131 we improved the MAP sensor readings stability so less (or even no) filtering is required.
