Hi people , can anyone help me to connect a wasted spark coil from a Ford Edis coil but it will work without amplifier module, I just need to know what ignition output (G8, G16 G9 or B16) I need to connect to a Bank1 and Bank2.
Connections for wasted spark
Re: Connections for wasted spark
it doesnt really matter because you can assign any Ignition Op to any ignition event in the cycle.
But generally for ease of setting it up i would attach
cyl 1+6 to IG op 1 (G1)
cyl 2+5 to IG op 2 (G16)
cyl 3+4 to IG op 3 (G9)
then set firing sequence 1,2,3,1,2,3
Or if its 4 cyl then
cyl 1+4 to IG op 1
cyl 2+3 to IG op 2
and sequence 1,2,1,2
cyl 1+4 to IG op 1
cyl 2+3 to IG op 2
p30esteves
Hi
Thank you RHD for your explanation
