S15 sr20det vtc settings
Posted: Sun Mar 06, 2016 10:21 pm
by impeller
Hello all i have a s15 sr20 with ecumaster wired without the pnp adapter. I have my vtc wired to injector #6. I can invert the sensor and make it turn on always. But i dont know the correct settings to make it function correctly. I dont know its tps based as well.
Re: S15 sr20det vtc settings
Posted: Mon Mar 07, 2016 12:19 am
by PSI-Motor
Use parameter output. You have to tune it to get the correct function.
Posted: Sat Mar 26, 2016 12:12 am
by Thilo
For best results, you have to have a dyno, and make two runs, one with fully open vtc and one with all time closed. so you can see, where it makes more power and say, ok, 3500rpm, then turn off would be good, or something equal.
