LC with Switch
+5v emu. Page 33 emu instructions
The fun starts now
Re: LC with Switch
you can actually use voltage from anywhere, the input action will be considered ON if the voltage is higher than about 3.5v and it will be considered OFF if the voltage is less that 1.5V
easy way is to use 2.2K resistor to 12V and then just have the switch pull the I/P to ground
