Hi,guys
Help my please,can't start VW ARC engine(1.6 16v GTI)with waste spark coil(032905106B).Primary trigger 60-2,camtrigger is half moon(one tooth).No spark,not working injectors,if it's possible someone give me basic settings for this engine
Engine not start
Re: Engine not start
that should be fairly straight forward the 60-2 crank and single tooth cam are direct selections, the first trigger tooth and trigger angle you might need to find by experiment and playing with ignition offset (0 or 1) Ignition OP's are selectible in wast spark configuration.
gorinycius
Hi men,thanks for your answer..But believe as I have tried,not working(only injectoros working in any strok,all together..i playng wint my car too long..)please help my!
Hi
Please post a scope along with your cam och primary settings.
