No trigger signal
Posted: Sun Apr 10, 2016 8:16 pm
Hey guys,
i have a Problem with my Setup.
Yesterday i would start the engine first time after installation.
First I have checked the signal on primary trigger and I don't have any scope.
I use a 60-2 trigger wheel and a Bosch motorsport VR-sensor 0261210136.
Here the things I've checked:
- check using the right pins B7 and B18
- choosing different air gap (Bosch tolerance 0,8 +/- 0,3)
- using a bypass wiring to exclude failure in wiring
- using another VR-Sensor
- check Setup (VR-Sensor, tooth wheel with 2 missing teeth, number of cylinders, enable scope and so on)
But I don't get it running.
No matter what primary trigger setup I have choose, I think I have to see some scope but there's nothing.
Today I measured the VR-Sensor signal with a osziloscope, see attached foto.
I think this signal is very fine, round about 7V and you see the two missing teeth.
Is it possible that I have a failure inside the EMU?
Or are there things I have to check too?
Hope you can give some tips
Kind regards
Alex
Kind regards
Alex
