Tuning issues SR20DET
Thilo
Post by Thilo » Mon Apr 11, 2016 12:23 pm
I've got two major problems with stetting correct lamba/ve.
1) I allways get lean readings from lambda sensor at fully closed throttle, but I allready disabled overrun fuelcut and decel enleanment. Is it just a sensor reading error and why does it do that? Also autotuner allways try to set VE to brutal high values. I just put values in, which seemed more realistic to me.
2) I allways get a very low ve in mid range RPM. My VE table just doesn't look right. And also, when I tune VE to correct lambda and change lamda target table after that, lambda readings are not as they should be. Another issue i found, when IAT values rise, my lambda values go lean.
I allready thought, that my Injectors are probaply not set right? I've got 750cc five-o-motorsport injectors (flowtestet by five-o-motorsport, actually 755cc) and injector dead times are also set right. I allready checkt fuel pressure, it's correct.
Engine is a SR20DET, bored to 87mm, 9:1 CR, BC Stage 3 Cams 272°/272° without VTC, stock s15 ball bearing turbo, bosch 2x2 wasted spark, NGK 2668 (BKR8EIX) regapped to 0,4mm.
Somebody got an idea?
Here you can see my curious VE.
Aktuell.emu
my map
(99.26KiB)Downloaded 95 times
derOJ
Re: Tuning issues SR20DET
Post by derOJ » Mon Apr 11, 2016 1:48 pm
Did you try another Lambda Sensor?
Checked the wiring to the Lambdacontroller?
Lean reading could also come from unburned fuel/air mixture. Maybe your ignition timing is much too late? just an idea...
Thilo
Post by Thilo » Mon Apr 11, 2016 2:03 pm
No, but the bosch 4.2 isn't that old. But I also do not have another one to try.
Wireing is ok. I've got the Lambda controlled by the EMU.
Timing isn't late in low pressure area. I attached my Tuning file, maby you could give it a quick look?
ihiryu
Post by ihiryu » Mon Apr 11, 2016 5:58 pm
Are you using the onboard wideband or an external controller? Did you check for exhaust leaks?
If you're using the onboard make sure you click "Enable Lambda Filter"
Thilo
Post by Thilo » Mon Apr 11, 2016 6:23 pm
Controlled by the EMU.
I think, i've got a tiny leak in my exsaust manifold, because of the EGT sensor. Does this influence Lambda readings that hard?
ihiryu
Post by ihiryu » Mon Apr 11, 2016 8:26 pm
Any air leaking could do it. Do you have the lambda filter enabled?
Thilo
Post by Thilo » Mon Apr 11, 2016 11:12 pm
Yes, I have. Ok so I will try to get it all leakproof and then post a reply. Thanks here :D
A.Dutsov
Post by A.Dutsov » Tue Aug 16, 2016 7:34 am
I dont have any leak, and my car wants same VE, its same engine, so maybe this engine wants that VE shape to run in the desired afr ...
Sm887
Post by Sm887 » Sun Aug 21, 2016 2:20 pm
If you could post a log file, it would have been easier to help.
nickbmw
Post by nickbmw » Sun Aug 21, 2016 2:44 pm
Injector linearity will affect the VE numbers needed. I wouldn't pay any attention to the lower ve numbers needed at the midrange.
Regarding the issue you have with lean afr when iat is rising, read here :
viewtopic.php?f=19&t=8817
Thilo
Post by Thilo » Sat Oct 15, 2016 1:12 am
just to give you a quick update:
I've got a complete new exhaust (which doesn't leak) and lambda readings are still bad at overrun, but hey, dont give a fuck, i think the fuel is just not burning right at overrun. My timing isn't late at overrun (something between 35 and 40 degree btdc). I really don't care, engine is running good, but just for my interest in engine physics, does anybody know, what's causing that phenomenon?
I also got my problem with the weird looking VE table under control, I just manualy flatend out the table and voila, engine is running at desired lambda. I think autotuner just pics too much transient data and has a problem with this rpm/map area.
The engine heat soaking problem has also almost gone since I managed my IAT to be heat shielded and vented my engine bay. The rest does the EGO correction :lol:
Thanks for helping
Thilo
Post by PSI-Motor » Sat Oct 15, 2016 2:12 am
You know that you shouldn't give the engine any fuel during overrun?
Of course your lambda won't show realistic numbers during overrun, no air into the engine + exesive fuel = kaoz for the lambdasensor.
Your sparkplugs, oil, lambdasensor, cylinder walls hatching will take a beating.
nickbmw
Post by nickbmw » Sat Oct 15, 2016 11:11 am
You have to set the fuel cut options correct. In this case, the fuel under (kpa). 17-20kpa is fine. It's not good for your engine to inject fuel at overrun, like mentioned already, plus you are raising your fuel consumption.
Thilo
Post by Thilo » Thu Nov 03, 2016 10:29 pm
Yes I know that, I was just hoping for some sort of popping noise and overrun flames :D
