ECU reset
Botasjr
ECU reset
Post by Botasjr » Sun Apr 17, 2016 2:09 pm
hi
im having a strange problem
after 2 years working, now the ecu seams to reset
there is the log file on dropbox
and the config file
is a 4 cylynder wasted spark engine, itb, 36-1 ckrank
i need some help
https://www.dropbox.com/s/09lirpf0k2wti ... 1.zip?dl=0
problem setup.zip
(8.62KiB)Downloaded 51 times
Botasjr
Re: ECU reset
Post by Botasjr » Tue Apr 19, 2016 10:45 am
no one can help me???
someone knows the emails of the gurus of ecumaster? the builders?
roquete
Re: ECU reset
Post by roquete » Tue Apr 19, 2016 12:22 pm
I had once a problem like that with a faulty tps shorting the 5v.
Botasjr
Re: ECU reset
Post by Botasjr » Tue Apr 19, 2016 4:38 pm
roquete wrote:I had once a problem like that with a faulty tps shorting the 5v.
im afraid of a 5v problem too,
i read your post about that.
but in this case i thing is diferent, its related with 5v circuit too, but not related with tps.
i have an oil pressure sensor, 5v / sensor ground and signal,
the wires broke with extreme heat, and touch one each other
and after that im having this problem, i dont have anymore those wires conected, but im afraid that the 5v internal circuit have this problem/is damaged.
could be possible?
regards
Re: ECU reset
Post by PSI-Motor » Tue Apr 19, 2016 6:36 pm
Would have been easier if you mentioned that from the beginning.
The only way to fix it is to send it to Ecumaster.
Botasjr
Re: ECU reset
Post by Botasjr » Tue Apr 19, 2016 6:39 pm
PSI-Motor wrote:Would have been easier if you mentioned that from the beginning.
i just have another ecu to test...
tomorrow i hope good news
Kisielisodd
ECUMASTER TEAM
Re: ECU reset
Post by Kisielisodd » Mon Sep 05, 2016 9:57 am
We are working on new firmware that will solve problems. We found source. Until new firmware will be release, we advice to downgrade firmware to version 1.126 and lower. This should temporarily solve problem.
Kisielisodd
ECUMASTER TEAM
Re: ECU reset
Post by Kisielisodd » Tue Sep 06, 2016 3:41 pm
https://dl.dropboxusercontent.com/u/286 ... 73exp1.exe
Upgrade firmware 1.173.
New version of firmware detect revision of processor and disable function causing error
