idle ignition timing control
nickbmw
Post by nickbmw » Sun Apr 24, 2016 12:33 pm
Hello everyone, i would like to ask, how do you control ignition timing at idle outside of the main ignition map? I want to set 5 degrees +-3 degrees correction for idle, but 16 degrees when tps is over 1% and idle is off, is there a way or the only way is to create a huge dip in the idle area of the main ignition map?
nickbmw
Re: idle ignition timing control
Post by nickbmw » Sun Apr 24, 2016 1:50 pm
I guess i answered my own question by using the tps vs map ignition map
