KNOCK SENSOR SET UP
aaronRX72JZ
HELLO I JUST INSTALLED THE 2 WIRE KNOCK SENSORS FROM WHP AND IM TRYING TO SET IT UP NEED HELP. I WAS GOING TO DO SOME 6500 RPM REVS AND ADJUST THE NOISE OUTPUT TO THAT. BUT THE VOLTAGE OUTPUT FROM THE SENSORS ARE REALLY LOW SO LOW THAT THE NOISE LEVEL TABLE WONT GO THAT LOW.
Re: KNOCK SENSOR SET UP
"Knock sensors / Sensor parameters" - there You can find "Gain" and "integrator" - in help for this window You have description how to set those two values.
Of course "Knock frequency is first value to be set
