Any MINI R53 users?
Posted: Mon May 16, 2016 11:02 pm
by LXM
I have one for my MINI project call "Project Kobalt" for MC2 magazine. I am curious to see if there are any users to get feedback. I am also the founder of "The League of Extraordinary Miniacs" Facebook group with 20k members worldwide and spread among 28 chapters as well as the main group with 16k+ members.
https://www.facebook.com/groups/LXMINIacs/
https://www.facebook.com/groups/207315236318919/
Re: Any MINI R53 users?
Posted: Tue May 17, 2016 11:23 am
by Kisielisodd
We are a user of Mini cooper S R53
We are using Mini in track days, and of course, engine is controlled by EMU.
Posted: Fri Jun 03, 2016 6:53 pm
by BobX
do you have any pictures of the EMU fited in the car ?
I'm currently instaling one on my R53, but not very happy with my fitment
Posted: Wed Feb 08, 2017 5:43 am
by Astroboy
Kisielisodd wrote:We are a user of Mini cooper S R53
Where do you have yours fitted?
Posted: Mon Feb 20, 2017 2:07 am
by slo_crx1
I mounted mine right next to the factory ecu location, and installed the CAN-BUS adapter inside the ecu box that I cut apart from the factory airbox.
Posted: Wed Mar 01, 2017 5:11 am
by Astroboy
My adapter board is in the stock ecu location and the standalone is on top of the fusebox on a custom bracket. Any ideas how to turn off the tyre pressure warning light and also the traction control light?
Posted: Thu Mar 02, 2017 4:31 pm
by slo_crx1
I don't think it's possible to turn them off just yet. The traction control switch would normally control the light on/off, so I would assume it would require additional code change to "switch" a traction map on and off like the oem ecu did. The pressure warning I thought was originally through a different module, but apparently not. Maybe a future update can address them, or figure some sort of CAN output to at least turn the lights off.
Posted: Thu Mar 09, 2017 5:47 pm
by Astroboy
This would be very useful in the UK as I don't believe cars will pass annual inspection with the lights illuinated
Posted: Fri Mar 10, 2017 10:33 pm
When we have access to stock Mini R53, we will try to reverse CAN to light off TCS and Tire Pressure
Posted: Wed Mar 29, 2017 5:15 pm
by Astroboy
I have the bluetooth module. Do you have any recommendations for the best location to tap into the CAN-BUS wiring? Am I right in thinking I won't need to use a 120ohm resistor if I don't create a new node?
Edit.....no resistor required
