i am having the following issue with my timing. Around specific area in the table the timing seems to go out of sync with the table and for some reason the EMU adds a few degrees of timing. This does not happen every time. I am concerned that this can be quite dangerous, if it happens under high load. As you can see it already resulted in knock under low boost. Its visible on the knock graphic below and also i heard it quite well on the headphones. It was not hard knock, but it was there
Forgot to add. Engine is 3SGTE gen2. Small CT26 turbo 1.2bar of boost. Pistons were changed to Wiseco due to broken ringland on a stock one. No other mods. Also screen is from a 2nd gear pull.
Edit: Ok after some more testing i can definitely say that this happens, when the throttle is opened suddenly and it takes around 0.2 sec for the timing to sync with the table. I was able to reproduce this every time although the timing difference varies from 1 to 4 degrees.
Problem found: Seems by mistake i have added 8 degrees in one of the cells of the Acc. Ignition table. And because it was only one cell i didn't see it , when i checked it first time. So all is fine ignore this thread.
