Cam and crank trigger options for Mazda
Posted: Wed Sep 09, 2015 5:13 am
Hi all,
Im looking to buy this unit to run my Mazda 626 turbo with the F2T 4cyl engine.
I want to run toyota coil on plugs and get rid of the factory ignitor, coil and distributor system.
I will use the factory distributor as a crank angle sensor.
The factory distributor has 3 VR sensors.
NE = 24 tooth wheel (no missing teeth) crank signal
G1 = TDC cylinder 1
G2 = TDC cylinder 2
My question is will the EMU ecu need all three signals or just NE and G1?
From what i read, i may not be able to run wasted spark setup using the stock signals?
Thanks in advance for any advice
G1 = TDC cylinder 1
G2 = TDC cylinder 2
