I do lot of streetraces here and we always start with rolling starts like in 2nd or 3rd gear.
I see the rolling anti-lag feature so i want it because i think it will give me a big benefit!!
Can anybody help me get this on my Escort Cosworth?
Cheers!!
Rolling Anti-Lag
- ktsirigotakis
Re: Rolling Anti-Lag
Hi m8 here in greece we do the same and i have engage with a button the PIT LIMITER at 60km/h for me it look that work fine you can tray it. the car locks at 60km/h and wont go farther.
You need just connect button to EMU analog input that will be used to activate the rolling antilag strategy.
Then setup Boost target to desired value. It should work, eventually tune the kP parameter
shadowlandz
Hello
I have a "MUX switch" that activates my ALS.
Can i use this to active rolling antilag?
What parameters can i set for this:
I want the turbo to make almost 1bar when i activate this button
Boostcontrol kp
Sparkcut kp
max spark cut
max ign retard
what is safe?
Cheers for the help
Boostcontrol kp
Sparkcut kp
max spark cut
max ign retard
what is safe?
Cheers for the help
shadowlandz
Nobody can help me get this set up? (parameters for testing)
Set enable option.
For input select the MUX switch that you are using (1,2 or 3).
Make test on the road and send here the log. Then I will be able to tell you how to adjust parameters
