Apexi boost solenoid?
Has anyone tried using the apexi boost control solenoid with the emu I have it hooked up and can't seem to get it to work correctly. It won't change DC.
Re: Apexi boost solenoid?
aaronRX72JZ wrote:Has anyone tried using the apexi boost control solenoid with the emu I have it hooked up and can't seem to get it to work correctly. It won't change DC.
If you have this one
and had isntaled flyback diode, it must work.
- Kisielisodd
- ECUMASTER TEAM
It should work even without flyback diode. Maybe solenoid is broken? When You connect +12 and ground directly does it work ?
i have it connected without flyback diode. it will work but only if i have it set to reverse polarity and the only thing i can change is the overall operation duration by lowering the solenoid frequency from 17Hz to 5. im guessing that it should be working without changing the polarity?
Thats the same one i have... i've manually tested the solenoid valve and its seems to be working correctly. and ive checked my wiring several times cant find any issues.Karel wrote:aaronRX72JZ wrote:Has anyone tried using the apexi boost control solenoid with the emu I have it hooked up and can't seem to get it to work correctly. It won't change DC.
any ideas? maybe a ECU issue? is there a way to check DC operation from the ECU with a multimeter?
Use some small bulb like 12V 5W and try to use DC 10-90% it should come brighter or darker............. this is the easiest way.aaronRX72JZ wrote:any ideas? maybe a ECU issue? is there a way to check DC operation from the ECU with a multimeter?
HI Are you running brand new ecu? or second hand?
its brand new. ill try the bulb thing this afternoon.gregpe wrote:HI Are you running brand new ecu? or second hand?
So I got it working. Turns out my emu won't operate the solenoid if the key is on the engine has to be running... Is this normal? Also the correction response is a little slow. I have frequency-25hz, Kp-1, Ki-16, Kd-0, and interval limit-400. not quite sure which to change to increase the DC error response speed.
Works perfectly with EMU .
