Apexi boost solenoid?
Posted: Tue Sep 22, 2015 9:12 am
by aaronRX72JZ
Has anyone tried using the apexi boost control solenoid with the emu I have it hooked up and can't seem to get it to work correctly. It won't change DC.
Re: Apexi boost solenoid?
Posted: Tue Sep 22, 2015 9:18 am
by Karel
aaronRX72JZ wrote:Has anyone tried using the apexi boost control solenoid with the emu I have it hooked up and can't seem to get it to work correctly. It won't change DC.
If you have this one
and had isntaled flyback diode, it must work.
Posted: Tue Sep 22, 2015 11:18 am
by Kisielisodd
It should work even without flyback diode. Maybe solenoid is broken? When You connect +12 and ground directly does it work ?
Posted: Tue Sep 22, 2015 8:23 pm
by aaronRX72JZ
i have it connected without flyback diode. it will work but only if i have it set to reverse polarity and the only thing i can change is the overall operation duration by lowering the solenoid frequency from 17Hz to 5. im guessing that it should be working without changing the polarity?
Posted: Tue Sep 22, 2015 8:24 pm
by aaronRX72JZ
Thats the same one i have... i've manually tested the solenoid valve and its seems to be working correctly. and ive checked my wiring several times cant find any issues.
Posted: Wed Sep 23, 2015 8:28 pm
by aaronRX72JZ
any ideas? maybe a ECU issue? is there a way to check DC operation from the ECU with a multimeter?
Posted: Thu Sep 24, 2015 8:27 am
by Karel
aaronRX72JZ wrote:any ideas? maybe a ECU issue? is there a way to check DC operation from the ECU with a multimeter?
Use some small bulb like 12V 5W and try to use DC 10-90% it should come brighter or darker............. this is the easiest way.
Posted: Thu Sep 24, 2015 3:49 pm
by gregpe
HI Are you running brand new ecu? or second hand?
Posted: Thu Sep 24, 2015 8:17 pm
by aaronRX72JZ
gregpe wrote:HI Are you running brand new ecu? or second hand?
its brand new. ill try the bulb thing this afternoon.
Posted: Fri Sep 25, 2015 10:54 pm
by aaronRX72JZ
So I got it working. Turns out my emu won't operate the solenoid if the key is on the engine has to be running... Is this normal? Also the correction response is a little slow. I have frequency-25hz, Kp-1, Ki-16, Kd-0, and interval limit-400. not quite sure which to change to increase the DC error response speed.
Posted: Sat Sep 26, 2015 1:42 pm
by KALI
Works perfectly with EMU . ;)
