RUNNING E85 ENRICH MAP BY %
aaronRX72JZ
Post by aaronRX72JZ » Sat May 28, 2016 8:15 pm
im looking to run E85 this week end, and i was wondering if there was a way to select the entire fuel map and add like 30% fuel? i didnt see anything in the hot keys. i know its possible in other standalone ecu, and im just wondering if the EMU has it also
Re: RUNNING E85 ENRICH MAP BY %
Post by PSI-Motor » Sat May 28, 2016 10:11 pm
Go to injector trim and type in 135-140% on all injector outputs.
aaronRX72JZ
Post by aaronRX72JZ » Sat May 28, 2016 10:37 pm
thank you!
Bartu
Post by Bartu » Tue May 31, 2016 7:00 pm
or multiply all map values by 1,3 - in manual for 2d/3d tables, you have description how to use * / + - calculations in all 2d/3d tables.
aaronRX72JZ
Post by aaronRX72JZ » Wed Jun 08, 2016 7:10 pm
im running the lsu 4.2 ive changed the fuel type to ethanol 85%. will the 3D AFR table need to be changed also or will that automatically convert Stoich to 14.5 AFR regardless of fuel type?
aaronRX72JZ
Post by aaronRX72JZ » Wed Jun 08, 2016 9:06 pm
never mind i see the option to change my 3D table to lambda thanks!
Post by PSI-Motor » Thu Jun 09, 2016 12:23 pm
Use gasoline settings.
