Hi all..
I am trying to connect a racepak IQ3 dash to the emu, without luck.
The plan is to use the haltech e11v2 protocol via can-bus.
so I have connected the can-bus module so it can imitate the haltec ecu.
Then I have the racepak 230-VM-EFIHAL2 adapter to take the haltech can data and convert it to v-net.
I have tried with various wiring looms, and of course with all settings in emu, without luck.
I really need some advice here.
Can-Bus
Re: Can-Bus
Just a question to the IQ3 Dash
Are you happy with it? and how do you find the software?
To your question did you try 120ohm resistor?
Re: Can-Bus
The owner of the car is or was quite happy with the iq3. He had the wolf v500 ecu before switching to the emu, and the dash was great. Now, not so great when no working.
The software is a bit confusing at first, but when you get to know it it's quite alright. Easy to change texts and scaling the values to suit your needs.
Yes I have tried with the 120 ohm resistor at both ends. I have tried to connect it in many ways with and without resistor/resistors.
