I have a bmw m50b25 singlevanos engine,
I have connected the connector called Ignition #1 to cylinder #1 , ignition #2 to cylinder #2 and so on, and i know the firing order of the engine i 153624
what should the ignition phase order and injector phase order be in the emu?
ignition order
Re: ignition order
Do you want to use sequential ignition and injection? Or wasted spark with semi sequential injection, or...something else?
With sequential ignition it would be
ignition Event 1 - Output #1
Event 2 - Output #5
Event 3 - output #3
Event 4 - Output #6
Event 5 - Output #2
Event 6 - Output #4
Event 2 - Output #5
Event 3 - output #3
Event 4 - Output #6
Event 5 - Output #2
Event 6 - Output #4
Re: ignition order
single vanos bmw i use firing order 536241 (event 1= IG op 5, event 2 = IG op 3 ...etc)
first trigger tooth 4
trigger angle 60
both edges falling (wiring dependant)
trigger angle 60
