autotune, how to enable?
Posted: Mon Jul 11, 2016 1:34 pm
by gesch
autotune how to enable?
do not want to work.
thank you
help please to include :D
Re: autotune, how to enable?
Posted: Mon Jul 11, 2016 2:23 pm
by Kisielisodd
Did you download and upgrade firmware in EMU ?
Download latest version of the software www.ecumaster.com/tv
Posted: Mon Jul 11, 2016 2:51 pm
by gesch
Kisielisodd wrote:Did you download and upgrade firmware in EMU ?
Download latest version of the software http://www.ecumaster.com/tv
downloaded Client for Windows 1.168 1 EXP. no car runs!
once connected to the ecu stops working!
how to turn on autotune??
Posted: Mon Jul 11, 2016 3:11 pm
by Kisielisodd
Open configuration -> log - Autotune window. In the Autotune window, press "ask" mark (help) and there will be manual, how to use autotune.
Other issue, if there is problem with engine start after firmware upgrade, try this :
- Save emu config map do hard drive
- upgrade firmware
- after upgrade open file -> set settings to default and save default configuration
- open config map from hard drive and save it to the memory.
Posted: Mon Jul 11, 2016 3:43 pm
by gesch
Kisielisodd wrote:Open configuration -> log - Autotune window. In the Autotune window, press "ask" mark (help) and there will be manual, how to use autotune.
- upgrade firmware
https://youtu.be/wxH2ZRuokvU
video
Posted: Mon Jul 11, 2016 4:25 pm
by Kisielisodd
Firmware version, 1.100 in Your EMU
autotune features add in 1.134
UPGRADE EMU FIRMWARE to the latest version
Posted: Mon Jul 11, 2016 4:28 pm
by gesch
Kisielisodd wrote:Firmware version, 1.100 in Your EMU
thank you!
turned out, it worked :D :D :D
