7mgte help
Posted: Fri Jul 15, 2016 9:11 pm
by ihiryu
Hey guys,
I got a 7mgte that I'm working on. I purchased the PNP adapter and got the base map from WHP. The car doesn't want to sync whatsoever. It'll just crank and crank. If I disable cam sync, I can get it fired up.
Should I just leave it disabled??
Re: 7mgte help
Posted: Sun Jul 17, 2016 4:12 am
Learn to use the SCOPE function this will help you find the cam signal. Sounds like you have a problem with the secondary trigger, maybe sensor or wiring
Re: 7mgte help
Posted: Tue Jul 26, 2016 11:45 pm
by ihiryu
Just an update, checked the air gap, and it was off a little. Did all three pads, according to the FSM, and now I have no sync whatsoever. I took a scope, and nothing shows.
Re: 7mgte help
Posted: Sat Jul 30, 2016 10:19 am
if the sensor is producing a signal then the scope will pick it up. If there is no signal on the scope then the wiring or the actual sensor itself has a problem
