Problem with the Firmwareupgrate
Posted: Wed Jul 20, 2016 10:26 pm
by DanielVWMk2VR6T4M
I have a problem with the firmware upgrade. (Win7 Laptop)
message : cannot enter boot loader
but status connected
where is the problem ?
next Problem is, my other Pc have Win10Pro. When i connect the emu with the PC is the message: This device is not able to work with US Windows version !
I have not a US Windows version.
ask for advice
greetings Daniel from Germany
Re: Problem with the Firmwareupgrate
Posted: Fri Jul 22, 2016 6:17 am
are you using software and firmware from here http://www.ecumaster.com/testVersions.html
Posted: Fri Jul 22, 2016 11:27 am
I use the current software version . same problem
Posted: Fri Jul 22, 2016 9:36 pm
by nickbmw
I had the same problem not long ago.
Posted: Sun Jul 24, 2016 4:44 pm
And how you solved the problem ?
Posted: Sun Jul 24, 2016 11:42 pm
by nickbmw
DanielVWMk2VR6T4M wrote:And how you solved the problem ?
I don't even know. Have you installed the latest version? There was a problem with one version, i think it was 1,167
Posted: Tue Jul 26, 2016 9:59 pm
Connect EMU to PC, turn ignition ON, wait about 10 seconds to be sure that USB connection with PC is establish.
Then run client software and select upgrade firmware option (even if the ECU is not connected).
The upgrade should start.
When for any reason the upgrade fail, the EMU stays in Boot Loader mode (because the program is not programmed correctly).
So the client software doesn't detect it, but it can be upgraded again.
Kuba
Posted: Thu Aug 04, 2016 12:32 pm
how can it be upgraded again ?
answer from tech-support :
".....Hello,
If ECU don't allow You to upgrade firmware, there is nothing You can do.
You must send ECu to us, this is the only way.
ECUMASTER
ul.Bronowicka 38/8
30-097 Kraków
Greetings
Artur Kisielewski...."
I sent the emu at my dealer
